Can't get past uploading of license file
Postby jcfischer » Mon Nov 13, 2017 1:56 pm
I have requested the 30 day trial for the Enterprise server. I used the normal installation procedure (without the mail server) on a fresh Ubuntu Xenial 16.04 VM in an OpenStack cloud.
The services seem to run and I can connect to the portal via the IP address. I see the first screen that asks me to setup the password and upload the license file.
As soon as I select the license file, a spinner starts up (Loading) and never finishes. I can't click the "Continue" button.
Screen Shot 2017-11-13 at 14.48.18.png (50.91 KiB) Viewed 394 times
Any ideas?
thanks
Jens-Christian
jcfischer
Re: Can't get past uploading of license file
Postby Maxim » Fri Nov 17, 2017 10:33 am
Hello jcfischer!
Try to get a new one, you can use the same mail.
