[Community Server] LDAP users can't login with 9.5
Re: [Community Server] LDAP users can't login with 9.5
Postby dsi-lille » Fri Nov 10, 2017 2:07 pm
with the help of my colleagues, we found the problem.
The problem is related with the error "LDAP Domain not found"
In the LDAPUtils.cs class from the ASC.ActiveDirectory library, you assume that the LDAP Domain contain necessarily DC attribute (line 43) :
private static readonly Regex DcRegex = new Regex("dc=([^,]+)", RegexOptions.Compiled | RegexOptions.CultureInvariant | RegexOptions.IgnoreCase);
This is not our case, we don't have any DC attribute. Our DN attributes looks like this :
uid=toto,ou=people,ou=example,ou=lorem,o=ipsum, c=fr
So we changed the regular expression like this :
private static readonly Regex DcRegex = new Regex("(dc|ou)=([^,]+)", RegexOptions.Compiled | RegexOptions.CultureInvariant | RegexOptions.IgnoreCase);
And all works (LDAP authentication, saving LDAP Settings and the LDAP synchronisation).
Could you, please, fix this rapidly ?
Thanks a lot,
Yoann.
dsi-lille
Postby Maxim » Sat Nov 11, 2017 8:05 am
Hello Yoann!
Can you send me results of the next command?
ldapsearch -x -H ldap://host:port -LLL -b "" -s base '(objectClass=*)' suppotedControls supportedCapabilities
Postby dsi-lille » Mon Nov 13, 2017 8:32 am
Hello Maxim,
we only have supportedControls attributes.
supportedCapabilities seems an exclusive attribute to Active Directory (we have Sun LDAP here) for me.
That's why it's the GetDomain method from LDApObjectExtension.cs that is used
        public static string GetDomain(this LdapObject ldapObject)
            if (ldapObject == null || string.IsNullOrEmpty(ldapObject.DistinguishedName))
                return null;
            return LdapUtils.DistinguishedNameToDomain(ldapObject.DistinguishedName);
and this lead to use DistinguishedNameToDomain method from LDAPUtils.cs class :
        public static string DistinguishedNameToDomain(string distinguishedName)
            if (string.IsNullOrEmpty(distinguishedName))
                return null;
            var matchList = DcRegex.Matches(distinguishedName);
            var dcList = matchList.Cast<Match>().Select(match => match.Groups[1].Value).ToList();
            return !dcList.Any() ? null : string.Join(".", dcList);
and this method uses an incorrect regular expression :
private static readonly Regex DcRegex = new Regex("(ou|dc)=([^,]+)", RegexOptions.Compiled | RegexOptions.CultureInvariant | RegexOptions.IgnoreCase);
I did my homework ;)
So now, can you fix this rapidly ?
Thanks,
Yoann
dsi-lille
Postby Maxim » Mon Nov 13, 2017 9:12 am
We need your domain component. Maybe there are values like "defaultNamingContext' or "rootDomainNamingContext"
What is version of SUN LDAP you use?
Postby dsi-lille » Mon Nov 13, 2017 10:20 am
Hello Maxim,
"defaultNamingContext' or "rootDomainNamingContext" are both specific to Active Directory...
we use the latest version (11) of SUN/Oracle Directory Server...
dsi-lille
Postby Maxim » Mon Nov 13, 2017 12:34 pm
Hello Yoann!
We cannot use your method, we cannot change regular expression otherwise other users will get incorrect domain error who use DC and OU in DN. We need DC
Is the DC specified in the LDAP connection settings in the UserDN or Group DN attributes?
Anyway, we will remove the restriction (next version 9.5.2) on synchronization. If the domain can not be found, it will be as "unknown" (with the ability to specify in the portal's configuration).
Postby dsi-lille » Mon Nov 13, 2017 1:06 pm
There is no DC in the user DN (only ou, o and c) and we doesn't use Group Membership.
Our tree LDAP does not contain DC attributes at all.
Great news !
When this new version will be available ?
We need the latest Document Server to solve this issue : viewtopic.php?f=31&t=10551
Is it Document Server version 5.0.3.41 compatible with Community Server 9.1 ?
Thanks,
Yoann
dsi-lille
Postby dsi-lille » Fri Nov 17, 2017 9:17 am
can i have answers to my questions ?
Thanks a lot,
Yoann
dsi-lille
Postby Maxim » Mon Nov 20, 2017 12:59 pm
Hello Yoann!
I cannot say exact time or date, i suppose it will be released in the middle of December i hope.
Yes, in that case do not enable JWT.
Postby dsi-lille » Mon Nov 20, 2017 2:10 pm
Hello Maxim,
thanks for your answer !
Yoann.
dsi-lille
PreviousNext
