[Community Server] LDAP users can't login with 9.5
Postby dsi-lille » Tue Nov 07, 2017 10:36 am
i upgraded our test environment with all the latest version and the ldap users can not login anymore.
I get this error :
Login Fail. Invalid username-password combination
The local account (portal admin) can login without problem.
I downgraded just the Community Server to 9.1.0.418, and with this version the LDAP user can login.
Thanks for your help,
Yoann
dsi-lille
Re: [Community Server] LDAP users can't login with 9.5
Postby kiar » Tue Nov 07, 2017 10:53 am
Same problem with an upgrade here after 2 syncs. With a fresh install, there's no problem.
kiar
Postby dsi-lille » Tue Nov 07, 2017 2:10 pm
Re,
if it can helps, i tried to save ldap settings in control panel and i get this error : LDAP domain not found.
In the log :
info: settings/ldap/status completed=true, id=852826d1-f54e-47b1-87a4-39c9d7412659, status=Loading LDAP base info, error=LDAP domain not found., percents=100, certificateConfirmRequest=null, source=, operationType=Save
dsi-lille
Postby dheimerl » Tue Nov 07, 2017 6:13 pm
I am having the same issue, upgraded to 9.5 and LDAP users cannot login. Were you able to figure anything out?
dheimerl
Postby kiar » Tue Nov 07, 2017 7:47 pm
I think you don't have to specify the protocol anymore, only the domain or the ip.
kiar
Postby dsi-lille » Wed Nov 08, 2017 7:18 am
I tried to remove the "LDAP://" : same error :-/
I checked the sources, they changed a lot of things about how the ldap authentication is handled...
anyway, thanks for your help ;)
dsi-lille
Postby dsi-lille » Fri Nov 10, 2017 9:17 am
an answer from the support would be really appreciate.
It's a huge bug...
Thanks,
Yoann
dsi-lille
Postby Maxim » Fri Nov 10, 2017 12:55 pm
Please specify did you try to authorize in LDAP server?
Postby dsi-lille » Fri Nov 10, 2017 1:36 pm
Hello Maxim,
yes, we need to authenticate to get access on all attributes.
Thanks,
Yoann
dsi-lille
Postby Maxim » Fri Nov 10, 2017 1:58 pm
And the problem is still there?
Did you click "SYNC" button?
LDAP example.jpg (51.05 KiB) Viewed 490 times
Note that now there are two fields - LOGIN and EMAIL
You should login via LOGIN or EMAIL
Please check portal user imported from LDAP server LOGIN and EMAIL fields - they could be changed.
Next
