Delete temp data
Delete temp data
Postby cantabrico » Mon Oct 16, 2017 2:05 pm
Hi. I have problem with "temp" data.
In OO I can use 1GB of data. In the past, I have made regular backups and erased them continuously. But now I can not make the backup because the disk is full even though the OO is almost empty. The problem will be in temp files, but I do not know what to delete.
Common 10GB
Common is realy empty (only 1 file 10KB)
Docker size
Folder size
Same data (maybe old backup)
Can I delete these files? Will OO be stable if he does not lose himself?
cantabrico
Re: Delete temp data
Postby Maxim » Tue Oct 17, 2017 7:54 am
Hello cantabrico!
It looks like these files are old backups.
I think yes, you can delete them.
