Periodical server (or just webserver ) hangs.
Postby rudais » Thu Oct 12, 2017 5:12 am
I in recent month have started encountering problem that server or just the webserver hangs after a while a week or two. System reboot helps. Problem being that OO no longer responds to web requests.
For now I have just given the VM on which server is installed more resources just to be on the safe side that it just inst related to lack of resources. I will be monitoring it more closely now.
Where should I start looking for source of these hangs? When digging around in forum I found that logs for docker are located here: "/app/onlyoffice/CommunityServer/logs".
For which services I should be looking for in docker when such situation occurs again?
Some details on system that I am running the server on:
== VM on KVM(proxmox):
- CPU: 4 cores
- RAM: 7-10GB
- Disk: virtio 50Gigs on SSD raid
- OS: Ubuntu Server v16.04.3, Docker v17.06.0-ce
- Only Office is running on docket installation: Control Panel, Community and Documents servers are all updated to latest
rudais
Re: Periodical server (or just webserver ) hangs.
Postby Maxim » Tue Oct 17, 2017 5:46 am
Hello rudais!
You can review all of them cause you do not know what exactly works wrong i suppose and search for ERROR, ngnix logs should be checked at first.
Postby rudais » Tue Oct 17, 2017 2:10 pm
Thanks for comment. I will check those logs if problem occurs again.
rudais
