Restore just 1 file
Restore just 1 file
Postby Khaji » Wed Sep 27, 2017 8:07 am
When i backup my data with the module i have all the doc and i restore all the doc.
I just want to restore just 1 document of 1 specific user.
How i can ?
Thx
Khaji
Re: Restore just 1 file
Postby Maxim » Thu Sep 28, 2017 7:52 am
Hello Khaji!
There is no way to restore one file only. Backup is dedicated to save all your data.
Postby Khaji » Thu Sep 28, 2017 3:20 pm
Ok....
It's stupid. I fi restore all data that's impact all users !
I've found a solution but it's DIY.
Download the savefile
Extract the save
find the name of doc in files_file
and find the doc in files/folder_XXXX
send the doc to the user
You're system is so lazy !
Please find a correct toold to do that !
Is not possible to continue anyway.
Over 100+ users.
Khaji
Postby Maxim » Fri Sep 29, 2017 10:54 am
Hello Khaji!
Please find a correct toold to do that!
Thank you for an advice!
You can restore the doc file if needed
Postby Khaji » Mon Oct 02, 2017 5:03 am
I'm not stupid man.
I know how restore file version.
But if a user delete a file, there is no way to restore just this file.
My user are very stupid and they are delete the junk to.
Actually the only way is:
1- Extract the tar.gz save.
2- Open with text editor <extracted folder>/databases/files/files_file
3- Search the name of wanted file <title> example-file.extension </title>
4- Find the id folder of file. 1 line up <folder_id>XX</folder_id>
5- Go to <extracted folder>/files/folder_XXXX
6- And find the good folder version and copy paste you're file into only office.
Khaji
Postby Maxim » Mon Oct 02, 2017 7:11 am
Hello Khaji!
I'm very glad that you have found a solution! :D :D
