SMTP problem in CRM
SMTP problem in CRM
Postby cantabrico » Fri Sep 15, 2017 7:27 am
Hello everyone.
I need help. I have a problem with SMTP settings in CRM.
Setting up SMTP in general settings works very well. But the same setting, with the same data in the CRM settings does not work. Email not sent. Can you help me?
SMTP working in : https://.../management.aspx?type=10
SMTP not working in: https://.../products/crm/settings.aspx?type=common
Where could be the problem?
Jan
cantabrico
Re: SMTP problem in CRM
Postby Maxim » Fri Sep 15, 2017 12:10 pm
Hello cantabrico!
Please send me via PM (private message) or you can post your SMTP settings to check it out.
Postby cantabrico » Mon Sep 18, 2017 6:22 am
I want to send you a message, but I'm not authorized: :shock:
Compose message
We are sorry, but you are not authorised to use this feature. You may have just registered here and may need to participate more to be able to use this feature.
cantabrico
Postby Maxim » Mon Sep 18, 2017 12:41 pm
Hello cantabrico!
Mail to support@onlyoffice.com with the link to this thread in the subject .
Postby Maxim » Mon Oct 09, 2017 12:30 pm
Hello cantabrico!
There was a bug (SMTP settings do not work in CRM) in CRM module.
We have fixed it in 9.5 release.
