[LDAP] Sync freeze
Re: [LDAP] Sync freeze
Postby Maxim » Fri Sep 15, 2017 12:42 pm
Hello kiar!
We have detected the problem (error), it's connected to StartTLS.
We will fix it next release in 2-3 weeks. There is nothing we can do now.
You can return your old configuration or wait some time till new release.
Postby kiar » Mon Sep 18, 2017 9:36 am
Ok, thanks !
kiar
Postby kiar » Thu Sep 21, 2017 7:50 pm
I have now a big problem, and it's maybe related : many users are not able to login anymore.
This is specific to OnlyOffice ( not a password issue ), because they can login in any other instance/CMS with Ldap-Auth.
I can see the request on my Ldap-Server, and this request returns no error to the OnlyOffice ( credentials are right ), but the session doesn't start.
Is there a way to correct it ?
It's not a problem for me to modify any file, or make a mysql request inside a container to correct this.
I've shown the source code of some files and the database structure, but I couldn't find the point.
Any help is very appreciated.
Thanks
kiar
Postby Maxim » Fri Sep 22, 2017 7:32 am
Hello kiar!
Did happen after update? What are the versions of containers? Did you change user's profile or filters?
Did you change smth. on LDAP server? Is there any addditional info that would help us?
Logs of Community Server could help us.
Postby kiar » Fri Sep 22, 2017 9:48 am
Hello Maxim,
I didn't change anything on the OnlyOffice server ( only a reboot on the ldap server ) : no update, no config change.
There was no config change on the ldap server.
# docker ps
CONTAINER ID        IMAGE                                                COMMAND                  CREATED             STATUS              PORTS        NAMES
520985529f28        onlyoffice4enterprise/communityserver-ee:9.1.0.418   "/usr/bin/dumb-ini..."   2 weeks ago         Up 8 days           0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp, 3306/tcp, 5280/tcp, 9865-9866/tcp, 9871/tcp, 9882/tcp, 0.0.0.0:5222->5222/tcp, 9888/tcp   onlyoffice-community-server
aad1b267f8ec        onlyoffice4enterprise/controlpanel-ee:2.1.1.105      "/usr/bin/dumb-ini..."   2 weeks ago         Up 11 days          80/tcp, 443/tcp, 9833-9834/tcp        onlyoffice-control-panel
b43631837dcf        onlyoffice4enterprise/documentserver-ee:4.4.3.7      "/bin/sh -c 'bash ..."   2 weeks ago         Up 11 days          80/tcp, 443/tcp        onlyoffice-document-server
3d825a72d591        onlyoffice/mailserver:1.6.27                         "/bin/sh -c 'expor..."   2 months ago        Up 11 days          0.0.0.0:25->25/tcp, 0.0.0.0:143->143/tcp, 3306/tcp, 0.0.0.0:587->587/tcp, 8081/tcp                                                  onlyoffice-mail-server
The command :
ldapsearch -H ldap://LDAPHOST:389 -b 'SEARCH_BASE' -D "BIND_DN" -W "(gidNumber=10000)" -ZZ
works well in both server console and container console.
I send you per pm the log from yesterday, but there's really nothing interesting ( I had to send an invitation to a user, and 2/3 false credentials ).
One question : are all the data ( documents, calendar event, project, ... ) in /app saved ?
The real question is : if I remove the docker container and reinstall it without removing /app, can I recover all the data ?
I don't think it would change anything to reinstall, just wan't to be sure
Thanks
kiar
Postby Maxim » Mon Sep 25, 2017 6:53 am
Hello kiar!
If folders are mapped from containers then - yes, data is saved. Anyway you should create backups.
Do not do it, i don't think thet it will help you. But generally yes, if you remove container and instal again, data will be restored. But as i see your enterprise works with MySQL 5.5 verision. Now script installs MySQL container with 5.7 version by default. That's why you need to install containers another way or to make a dump of MySQL version 5.5 database and restore it on new container with MySQL 5.7 version.
Postby kiar » Tue Sep 26, 2017 8:43 am
No, I will not do a reinstall, I althought think that it will not solve my problem.
Am I the only one who has this problem connecting with ldap ?
Please let me know if there is a patch to correct this.
Thanks !
kiar
Postby Maxim » Thu Sep 28, 2017 11:01 am
Hello kiar!
Of i will. I'm agree with you here that it won't solve the problem
Postby kiar » Thu Oct 05, 2017 7:45 pm
It's getting worse for our school : our license expire on next week. After this date, I doubt we can do an update anymore.
How far are your investigations ?
Thanks
kiar
Postby Maxim » Fri Oct 06, 2017 7:07 am
Hello kiar!
We have fixed it in 9.5 version which is going to be released soon.
Why so? What email you used for the licence?
You are using ONLYOFFICE Education Edition?
PreviousNext
