[LDAP] Sync freeze
[LDAP] Sync freeze
Postby kiar » Wed Sep 06, 2017 6:36 am
I have tested the sync of the ldap account in the last version ( CP 2.1.1.105 and Community 9.1.0.418 ), but it goes not further than 15%, and nothing is done ( no new user added, no old user deleted ).
The ldap bind with my auth server works fine, i've seen it in the logs of the auth server, but i didn't find any error in the logs of controlpanel or community-server.
In this topic viewtopic.php?f=31&t=9451&p=13309#p13309 i've had the problem that many users didn't had an email attribute on the auth server, but that's not the problem this time : all user have an email attribute.
Any ideas ?
Thanks !
kiar
Re: [LDAP] Sync freeze
Postby Maxim » Wed Sep 06, 2017 7:17 am
Hello kiar!
Please specify did you sync ldap before or you test ldap sync first time?
Also it would be great anyway to send us via PM Community Server's logs.
Postby kiar » Wed Sep 06, 2017 7:27 am
I use the sync since last year, it's not the first time.
kiar
Postby kiar » Sat Sep 09, 2017 10:21 pm
Sorry for the late reply.
The logs since tuesday :
2017-09-05 11:42:02,225 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getbackupschedule.json - Server error
System.ServiceModel.EndpointNotFoundException: System error. ---> System.Net.WebException: Error: ConnectFailure (Connection refused) ---> System.Net.Sockets.SocketException: Connection refused
  at System.Net.Sockets.Socket.Connect (System.Net.EndPoint remoteEP) [0x000b6] in <2b0d86369d72459baed0cee98a8e578a>:0
  at System.Net.WebConnection.Connect (System.Net.HttpWebRequest request) [0x0016d] in <2b0d86369d72459baed0cee98a8e578a>:0
  at System.Net.HttpWebRequest.EndGetRequestStream (System.IAsyncResult asyncResult) [0x0003a] in <2b0d86369d72459baed0cee98a8e578a>:0
  at System.ServiceModel.Channels.HttpRequestChannel+<>c__DisplayClass6_1.<BeginProcessRequest>b__0 (System.IAsyncResult r) [0x0001d] in <69eced05b2aa4b18811862832d0c91db>:0
  at <0x00000 + 0x00000> <unknown method>
  at (wrapper remoting-invoke) ASC.Core.Common.Contracts.IBackupService:GetSchedule (int)
  at ASC.Core.Common.Contracts.BackupServiceClient.GetSchedule (System.Int32 tenantId) [0x00007] in <d597448f86e941acaa2769b1ca5f871e>:0
  at ASC.Web.Studio.Core.Backup.BackupAjaxHandler.GetSchedule () [0x00014] in <2f5bad22d84942bf85da54f5215ed8f9>:0
  at ASC.Api.Portal.PortalApi.GetBackupSchedule () [0x00000] in <4ada100c4b2a42d99c5ee69588821601>:0
  at System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00032] in <a07d6bf484a54da2861691df910339b1>:0
2017-09-05 11:42:02,646 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getBackupProgress.json - Server error
  at (wrapper remoting-invoke) ASC.Core.Common.Contracts.IBackupService:GetBackupProgress (int)
  at ASC.Core.Common.Contracts.BackupServiceClient.GetBackupProgress (System.Int32 tenantId) [0x00007] in <d597448f86e941acaa2769b1ca5f871e>:0
  at ASC.Web.Studio.Core.Backup.BackupAjaxHandler.GetBackupProgress () [0x00014] in <2f5bad22d84942bf85da54f5215ed8f9>:0
  at ASC.Api.Portal.PortalApi.GetBackupProgress () [0x00000] in <4ada100c4b2a42d99c5ee69588821601>:0
2017-09-05 11:44:58,585 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
System.InvalidOperationException: Trop d'opérations LDAP.
  at ASC.Api.Settings.SettingsApi.SyncLdap () [0x0005e] in <1599c273017d4a02859f130841246bdf>:0
2017-09-05 11:45:07,187 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-05 11:46:56,052 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-05 11:49:40,858 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-05 11:56:22,083 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getbackupschedule.json - Server error
2017-09-05 11:56:22,397 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getBackupProgress.json - Server error
2017-09-05 11:56:34,868 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-05 12:33:29,097 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getbackupschedule.json - Server error
2017-09-05 12:33:29,413 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getBackupProgress.json - Server error
2017-09-05 12:33:33,571 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-05 12:47:51,925 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getbackupschedule.json - Server error
2017-09-05 12:47:52,267 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getBackupProgress.json - Server error
2017-09-05 12:48:03,837 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-05 14:09:09,028 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getbackupschedule.json - Server error
2017-09-05 14:09:09,204 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getBackupProgress.json - Server error
2017-09-05 14:09:24,619 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-05 16:00:03,873 ERROR [Threadpool worker] ASC.Api - method error: http://127.0.0.1/api/2.0/mail/accounts.json - Server error
2017-09-05 16:00:23,152 ERROR [Threadpool worker] ASC.Api - method error: http://127.0.0.1/api/2.0/mail/accounts.json - Server error
2017-09-05 16:00:39,230 ERROR [Threadpool worker] ASC.Api - method error: http://127.0.0.1/api/2.0/mail/accounts.json - Server error
2017-09-05 16:01:03,705 ERROR [Threadpool worker] ASC.Api - method error: http://127.0.0.1/api/2.0/mail/accounts.json - Server error
2017-09-05 16:13:38,038 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getbackupschedule.json - Server error
2017-09-05 16:13:38,395 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getBackupProgress.json - Server error
2017-09-05 16:13:44,761 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-05 16:15:30,317 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getbackupschedule.json - Server error
2017-09-05 16:15:30,479 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getBackupProgress.json - Server error
2017-09-05 16:15:35,692 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-05 16:21:02,742 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getbackupschedule.json - Server error
2017-09-05 16:21:02,888 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/portal/getBackupProgress.json - Server error
2017-09-05 17:09:20,682 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap - Server error
  at ASC.Api.Settings.SettingsApi.SaveLdapSettings (System.String settings, System.Boolean acceptCertificate) [0x0005e] in <e51b870225394db2abc7355e72d1dfa9>:0
2017-09-05 21:51:55,057 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
  at ASC.Api.Settings.SettingsApi.SyncLdap () [0x0005e] in <e51b870225394db2abc7355e72d1dfa9>:0
2017-09-05 21:56:02,463 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-05 22:13:35,507 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-06 14:46:57,844 ERROR [Threadpool worker] ASC.Api - method error: http://127.0.0.1/api/2.0/mail/accounts.json?__=17273&__=17273 - Server error
2017-09-06 16:24:38,302 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-07 09:07:35,468 ERROR [Threadpool worker] ASC.Api - method error: https://172.18.0.4/api/2.0/people/password.json?__=60481 - Server error
System.Exception: Der Benutzer mit der Adresse michael.hegemann@gmx.de wurde nicht gefunden
  at ASC.Web.Studio.Core.Users.UserManagerWrapper.SendUserPassword (System.String email) [0x000b1] in <77c7a14e19084d7ba9c709dd5cfefba2>:0
  at ASC.Api.Employee.EmployeeApi.SendUserPassword (System.String email) [0x00000] in <aff3cedb8e5d49019038ebb184baa7ba>:0
2017-09-07 09:07:43,693 ERROR [Threadpool worker] ASC.Api - method error: https://172.18.0.4/api/2.0/people/password.json?__=29554 - Server error
System.Exception: Der Benutzer mit der Adresse hegemann@gmx.de wurde nicht gefunden
2017-09-07 09:07:55,307 ERROR [Threadpool worker] ASC.Api - method error: https://172.18.0.4/api/2.0/people/password.json?__=872576 - Server error
System.Exception: Kennwortwiederherstellung für LDAP Benutzer ist verboten
  at ASC.Web.Studio.Core.Users.UserManagerWrapper.SendUserPassword (System.String email) [0x000e4] in <77c7a14e19084d7ba9c709dd5cfefba2>:0
2017-09-07 10:40:52,933 ERROR [Threadpool worker] ASC.Api - method error: http://127.0.0.1/api/2.0/mail/accounts.json - Server error
2017-09-07 10:41:03,164 ERROR [Threadpool worker] ASC.Api - method error: http://127.0.0.1/api/2.0/mail/accounts.json - Server error
2017-09-07 20:21:29,617 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-07 20:22:57,386 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap/sync - Server error
2017-09-07 20:42:53,347 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap - Server error
2017-09-07 20:45:56,816 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap - Server error
2017-09-08 09:59:57,089 ERROR [Threadpool worker] ASC.Api - method error: https://172.18.0.4/api/2.0/people.json?__=657905 - Server error
System.Exception: Utilisateur avec la même adresse e-mail est déjà inscrit
  at ASC.Web.Studio.Core.Users.UserManagerWrapper.AddUser (ASC.Core.Users.UserInfo userInfo, System.String password, System.Boolean afterInvite, System.Boolean notify, System.Boolean isVisitor, System.Boolean fromInviteLink, System.Boolean makeUniqueName) [0x0003d] in <77c7a14e19084d7ba9c709dd5cfefba2>:0
  at ASC.Api.Employee.EmployeeApi.AddMember (System.Boolean isVisitor, System.String email, System.String firstname, System.String lastname, System.Guid[] department, System.String title, System.String location, System.String sex, ASC.Specific.ApiDateTime birthday, ASC.Specific.ApiDateTime worksfrom, System.String comment, System.Collections.Generic.IEnumerable`1[T] contacts, System.String files) [0x00107] in <aff3cedb8e5d49019038ebb184baa7ba>:0
2017-09-08 13:03:33,813 ERROR [Threadpool worker] ASC.Api - method error: http://127.0.0.1/api/2.0/mail/accounts.json?__=827593&__=827593 - Server error
2017-09-09 21:47:45,527 ERROR [Threadpool worker] ASC.Api - method error: https://127.0.0.1/api/2.0/settings/ldap - Server error
It's weird, it's not in DEBUG mode since the upgrade to Debian 9 ( done this summer ).
OnlyOffice just works fine on Debian 9, only this Ldap Sync is for us a big problem.
It stucks at 15% :
Is it normal that the command for the docker community/controlpanel container is dumb-init ?
# docker ps
CONTAINER ID        IMAGE                                                COMMAND                  CREATED             STATUS              PORTS        NAMES
520985529f28        onlyoffice4enterprise/communityserver-ee:9.1.0.418   "/usr/bin/dumb-ini..."   4 days ago          Up 10 minutes       0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp, 3306/tcp, 5280/tcp, 9865-9866/tcp, 9871/tcp, 9882/tcp, 0.0.0.0:5222->5222/tcp, 9888/tcp   onlyoffice-community-server
aad1b267f8ec        onlyoffice4enterprise/controlpanel-ee:2.1.1.105      "/usr/bin/dumb-ini..."   4 days ago          Up 10 minutes       80/tcp, 443/tcp, 9833-9834/tcp        onlyoffice-control-panel
b43631837dcf        onlyoffice4enterprise/documentserver-ee:4.4.3.7      "/bin/sh -c 'bash ..."   4 days ago          Up 10 minutes       80/tcp, 443/tcp        onlyoffice-document-server
3d825a72d591        onlyoffice/mailserver:1.6.27                         "/bin/sh -c 'expor..."   7 weeks ago         Up 10 minutes       0.0.0.0:25->25/tcp, 0.0.0.0:143->143/tcp, 3306/tcp, 0.0.0.0:587->587/tcp, 8081/tcp                                                  onlyoffice-mail-server
This is getting worse : some customer cannot login anymore, and the file web.09-09.log don't show any error ( it stays empty ). However, the login process works for almost all customers.
Do you need other logs ?
kiar
Postby kiar » Sun Sep 10, 2017 7:22 pm
More specific, the following command on the OnlyOffice server returns what's expected from the ldap server :
# ldapsearch -H ldap://LDAPHOST:389 -b 'SEARCH_BASE' -D "BIND_DN" -W "(gidNumber=10000)" -ZZ
In ControlPanel :
Maybe if I succeed to enable the debug mode in CommunityServer, I can find out in web.api.log where the problem is.
kiar
Postby kiar » Tue Sep 12, 2017 8:57 pm
No idea ?
kiar
Postby Maxim » Wed Sep 13, 2017 10:53 am
Hello kiar!
1 Try to disable just for testing StartTLS
2 Specify please did you run command from the host machine or inside the Community Server container?
Try to run from inside of the container
3
Is it normal that the command for the docker community/controlpanel container is dumb-init?
Yes, it's normal
4
Yesб you should try.
Postby kiar » Wed Sep 13, 2017 8:24 pm
Hello Maxim,
Thanks for your answer.
Maxim wrote:1 Try to disable just for testing StartTLS
Don't work. I have to use the StartTls handle.
Maxim wrote:2 Specify please did you run command from the host machine or inside the Community Server container?
It runs from outside and inside the container, but not without the option -ZZ ( StartTls ).
Maxim wrote:4
Yes you should try.
How ?
kiar
Postby Maxim » Thu Sep 14, 2017 6:59 am
Hello kiar!
Logs
tail -f /app/onlyoffice/CommunityServer/logs/web.09-13.log
Actual logs of the day
tail -f /app/onlyoffice/CommunityServer/logs/web.`date '+%m-%d'`.log
To enable detailed log
docker exec -it onlyoffice-community-server sed -i 's/<level value="WARN" \/>/<level value="ALL" \/>/g' /var/www/onlyoffice/WebStudio/web.log4net.config && docker exec -it onlyoffice-community-server service monoserve restart
To get back default log
docker exec -it onlyoffice-community-server sed -i 's/<level value="ALL" \/>/<level value="WARN" \/>/g' /var/www/onlyoffice/WebStudio/web.log4net.config && docker exec -it onlyoffice-community-server service monoserve restart
Postby kiar » Fri Sep 15, 2017 4:55 am
Hello Maxim,
Maxim wrote:To enable detailed log
Thanks, that was what I was looking for.
Now I get the following error ( the only error, I think it's relate my problem ) :
2017-09-14 08:58:29,983 ERROR [Threadpool worker] ASC.ActiveDirectory.DirectoryServices.LdapSettingsChecker - Wrong User DN parameter: ou=accounts,dc=domain,dc=org. System.SystemException: Thread creation failed.
  at System.Threading.Thread.StartInternal (System.Security.Principal.IPrincipal principal, System.Threading.StackCrawlMark& stackMark) [0x00032] in <a07d6bf484a54da2861691df910339b1>:0
  at System.Threading.Thread.Start (System.Threading.StackCrawlMark& stackMark) [0x00028] in <a07d6bf484a54da2861691df910339b1>:0
  at System.Threading.Thread.Start () [0x00002] in <a07d6bf484a54da2861691df910339b1>:0
  at Novell.Directory.Ldap.Connection.startReader () [0x00021] in <44216eed10644702a72b7bbc0d1077c9>:0
  at Novell.Directory.Ldap.Connection.connect (System.String host, System.Int32 port, System.Int32 semaphoreId) [0x001ad] in <44216eed10644702a72b7bbc0d1077c9>:0
  at Novell.Directory.Ldap.Connection.connect (System.String host, System.Int32 port) [0x00001] in <44216eed10644702a72b7bbc0d1077c9>:0
  at Novell.Directory.Ldap.LdapConnection.Connect (System.String host, System.Int32 port) [0x00080] in <44216eed10644702a72b7bbc0d1077c9>:0
  at ASC.ActiveDirectory.Novell.NovellLdapSearcher.Search (System.String login, System.String password, System.String server, System.Int32 portNumber, System.Int32 scope, System.Boolean startTls, System.String searchFilter, System.String disnguishedName, System.String[] attributes) [0x00082] in <91315a27d68d46eda62b5c7ef6dad6fa>:0
  at ASC.ActiveDirectory.Novell.NovellLdapHelper.CheckUserDN (System.String userDN, System.String server, System.Int32 portNumber, System.Boolean authentication, System.String login, System.String password, System.Boolean startTls) [0x0001c] in <91315a27d68d46eda62b5c7ef6dad6fa>:0
  at ASC.ActiveDirectory.Novell.NovellLdapSettingsChecker.CheckUserDN (System.String userDN, System.String server, System.Int32 portNumber, System.Boolean authentication, System.String login, System.String password, System.Boolean startTls) [0x00002] in <91315a27d68d46eda62b5c7ef6dad6fa>:0
2017-09-14 08:58:30,000 ERROR [Threadpool worker] ASC.Web.Studio.Core.Import.LDAP.LDAPOperation - Internal server error. System.Threading.ThreadAbortException
  at ASC.ActiveDirectory.Novell.NovellLdapSettingsChecker.CheckUserDN (System.String userDN, System.String server, System.Int32 portNumber, System.Boolean authentication, System.String login, System.String password, System.Boolean startTls) [0x00032] in <91315a27d68d46eda62b5c7ef6dad6fa>:0
  at ASC.ActiveDirectory.Novell.NovellLdapSettingsChecker.CheckSettings (ASC.ActiveDirectory.LDAPUserImporter importer, System.Boolean acceptCertificate) [0x00105] in <91315a27d68d46eda62b5c7ef6dad6fa>:0
  at ASC.Web.Studio.Core.Import.LDAP.LDAPOperation.RunJob (ASC.Common.Threading.DistributedTask _, System.Threading.CancellationToken cancellationToken) [0x00124] in <77c7a14e19084d7ba9c709dd5cfefba2>:0
Despite the first line, the DN is right, I use it overall in many other systems and CMS.
I don't know how to go further.
kiar
Next
