Disable Certain File Type Upload
Postby vponteras.cri » Mon Aug 28, 2017 9:17 pm
I just want to know how to disable upload for certain file types, because I saw this on the javascript file.
        if (config.UploadableExts && jq.inArray(ext, config.UploadableExts) == -1) {
            displayInfoPanel(config.NotSupportedFormatErrorMsg || "Sorry, this file format isn't supported", true);
            return false;
User avatar
vponteras.cri
Re: Disable Certain File Type Upload
Postby Alexander_mb » Tue Aug 29, 2017 2:28 pm
Hello vponteras.cri ,
The part of code you have mentioned is from the file upload manager, which is used only in Forum section of the Community module. The one used in Documents module is different and there are no file type limits.
Alexander_mb
Postby vponteras.cri » Thu Aug 31, 2017 2:25 pm
Ah I see. So is there any other way to achieve this?
User avatar
vponteras.cri
Postby Alexander_mb » Mon Sep 04, 2017 9:56 am
Unfortunately, there is no opportunity to do this.
Alexander_mb
