[solved] Problem with upgrades
Postby bevito » Thu Jul 20, 2017 5:58 pm
I just try to update our docker installation (try to update community server / control panel / document server).
I stopped all containers, delete old containers and images.
I used the latest script enterprise-install.sh and I used
bash enterprise-install.sh -ims false
Everything seems to be running :
CONTAINER ID        IMAGE                                                COMMAND                  CREATED             STATUS              PORTS        NAMES
59f45125209b        onlyoffice4enterprise/communityserver-ee:9.1.0.393   "/app/onlyoffice/r..."   27 minutes ago      Up 10 minutes       0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp, 3306/tcp, 5280/tcp, 9865-9866/tcp, 9871/tcp, 9882/tcp, 0.0.0.0:5222->5222/tcp, 9888/tcp   onlyoffice-community-server
49914d6b6162        onlyoffice4enterprise/controlpanel-ee:2.1.0.93       "/usr/bin/dumb-ini..."   28 minutes ago      Up 18 minutes       80/tcp, 443/tcp, 9833-9834/tcp        onlyoffice-control-panel
458eaa484def        onlyoffice4enterprise/documentserver-ee:4.4.1.38     "/bin/sh -c 'bash ..."   28 minutes ago      Up 12 minutes       80/tcp, 443/tcp        onlyoffice-document-server
When I try to log to OnlyOffice, I have a blank page.
When I try to connect on the server, with elinks command, I have this message :
elinks 127.0.0.1
Erreur HTTP 402: Payment Required
Strange thing : I upload and activate our licence before updating OnlyOffice.
Have you any ideas how I can solve those issues ?
Thanks a lot for your help.
bevito
Re: Problem with upgrades
Postby bevito » Fri Jul 21, 2017 8:30 am
I managed to reinstall the previous versions of Document Server and Community Server.
- I removed all docker's images
- I download the installation bash script
- I edited the vars
COMMUNITY_VERSION="9.0.0.300";
DOCUMENT_VERSION="4.3.3.4";
Now OnlyOffice works again :
1b689bc79a45        onlyoffice4enterprise/communityserver-ee:9.0.0.300   "/usr/bin/dumb-ini..."   8 minutes ago       Up 8 minutes        0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp, 3306/tcp, 5280/tcp, 9865-9866/tcp, 9871/tcp, 9882/tcp, 0.0.0.0:5222->5222/tcp, 9888/tcp   onlyoffice-community-server
089be46be970        onlyoffice4enterprise/controlpanel-ee:2.1.0.93       "/usr/bin/dumb-ini..."   9 minutes ago       Up 9 minutes        80/tcp, 443/tcp, 9833-9834/tcp        onlyoffice-control-panel
79ed3312a275        onlyoffice4enterprise/documentserver-ee:4.3.3.4      "/bin/sh -c 'bash ..."   9 minutes ago       Up 9 minutes        80/tcp, 443/tcp        onlyoffice-document-server
When I logged in, as an administrator, the licence was gone so I upload the file again.
In your opinion, can I update Community Server and Document Server with control panel ?
Thanks for your help.
bevito
Postby Maxim » Fri Jul 21, 2017 9:54 am
Hello bevito!
Yes you can.
Postby bevito » Fri Jul 21, 2017 5:36 pm
Hi Maxim,
I tried to update Document Server and Community Server with Control Panel.
There was no problem with Document Server, but I had the same problem with Community Server.
When I tried to update Community Server from 9.0.0.300 to 9.1.0.393, the portal restarted and then the portal displayed a blank page.
On the server, if I use elinks, I've got the same error as before :
I reinstalled all the containers using the same method (edit vars to specify the 9.0.0.300 Community version).
9ceca4ab777e        onlyoffice4enterprise/communityserver-ee:9.0.0.300   "/usr/bin/dumb-ini..."   22 minutes ago      Up 22 minutes       0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp, 3306/tcp, 5280/tcp, 9865-9866/tcp, 9871/tcp, 9882/tcp, 0.0.0.0:5222->5222/tcp, 9888/tcp   onlyoffice-community-server
91409e80caaa        onlyoffice4enterprise/controlpanel-ee:2.1.0.93       "/usr/bin/dumb-ini..."   23 minutes ago      Up 23 minutes       80/tcp, 443/tcp, 9833-9834/tcp        onlyoffice-control-panel
4ca4a5428062        onlyoffice4enterprise/documentserver-ee:4.4.1.38     "/bin/sh -c 'bash ..."   24 minutes ago      Up 24 minutes       80/tcp, 443/tcp        onlyoffice-document-server
OnlyOffice is working, but the licence is gone.
I uploaded the licence file again.
I'm afraid that if I try to update again, I'll run in the same problem.
Is there a way to check that licence file is working properly ?
What can I do ?
Thanks a lot.
bevito
Postby Maxim » Mon Jul 24, 2017 6:51 am
Hello bevito!
If you use Onlyoffice Enterprise Edition for Docker and installed it with installation script then folders are mapped into app/onlyoffice. And the license.lic file is on the path /app/onlyoffice/DocumentServer/data. Udpating process is the same like you would do it mannually: stop containers, delete containers, download new containers and run new containers.
That is very strange that the licence is gone! I cannot say why it happend.
You can send us your license.lic file to check.
Postby bevito » Mon Jul 24, 2017 7:03 am
Hi Maxim,
Thanks for your answer.
The licence file is indeed in the /app/onlyoffice/DocumentServer/data folder.
ls -l /app/onlyoffice/DocumentServer/data/license.lic
-rwxrwxrwx 1 Debian-exim netdev 534 juil. 21 19:17 /app/onlyoffice/DocumentServer/data/license.lic
How can I send you the licence file (is there a special e-mail address) ?
Again : thanks a lot for your help.
bevito
Postby Maxim » Tue Jul 25, 2017 7:18 am
Hello bevito!
Send us to support@onlyoffice.com with link to that threat.
Re: [solved] Problem with upgrades
Postby bevito » Tue Aug 01, 2017 9:43 am
Hello Maxim,
I would like to thanks everyone at OnlyOffice support.
Our problem is solved
I don't know what was the cause of the problem, but thank you !
bevito
Postby Maxim » Wed Aug 02, 2017 8:43 am
Hello bevito!
Thank you for such kind words.
We are glad to help our customers!
