Download Failed error when opening document
Postby Khaji » Tue Jul 18, 2017 11:17 am
Hi all,
I have a EE OnlyOffice and HTTPS work for Community Server but when i acces to Document Server i hace this error about 2/3 min "Download Failed. Press OK to return to ..."
Error in console
[2017-07-18 09:44:29.506] [ERROR] nodeJS - error downloadFile:url=https://ged.mycaelis.fr:443/products/files/httphandlers/filehandler.ashx?action=stream&fileid=99&version=1&stream_auth=238066947752.R5HY0HMQTADHTVECNY5UDSFMTGEDY8SNNC83ZDY3VW&X-REWRITER-URL=https%3a%2f%2f10.62.255.28%3a443;attempt=1;code:ETIMEDOUT;connect:true;(id=xayBaS0_aSzVPpLR1ww_)
Error: ETIMEDOUT
    at Timeout._onTimeout (/var/www/onlyoffice/documentserver/server/Common/node_modules/request/request.js:852:19)
    at ontimeout (timers.js:386:14)
    at tryOnTimeout (timers.js:250:5)
    at Timer.listOnTimeout (timers.js:214:5)
I have Docker Version and all work in http but not in https.
Thx for help.
Regard
D
Khaji
Re: Download Failed error when opening document
Postby Maxim » Tue Jul 18, 2017 11:36 am
Hello Khaji!
Did you install using Control panel?
Do you use self-signed or commecial SSL certs?
Postby Khaji » Tue Jul 18, 2017 11:38 am
Hey !
1) Yes
2) Commercial SSL Cert
Thx
Khaji
Postby Khaji » Tue Jul 18, 2017 12:22 pm
Hello Maxim,
Yes i have install using control panel.
I use a commercial SSL certs.
Thx for help.
Khaji
Postby Khaji » Wed Jul 26, 2017 8:06 am
Can i have a response with solution ?
Thx
Khaji
Postby Maxim » Thu Jul 27, 2017 6:30 am
Hello Khaji!
Please specify did you update onlyoffice server to the latest version?
Postby Khaji » Thu Jul 27, 2017 7:36 am
Yes the last update are install.
Khaji
