Feature request: DOTX template files
Postby jakobssystems » Sun May 28, 2017 3:57 pm
Today I've got the feedback that .dotx files are not editable by OnlyOffice. Since these are just .docx used as templates I think this should be no problem in making them editable. Perhaps in the same manner as they used in Microsoft Office? Just a feature request...
jakobssystems
Re: Feature request: DOTX template files
Postby Maxim » Mon May 29, 2017 7:03 am
Hello jakobssystems!
You are right (see here). Honestly to say we think that there is no need to implement DOTX template into OnlyOffice. DOTX format is not so widespread.
Postby jakobssystems » Mon May 29, 2017 7:24 am
Maxim wrote:Hello jakobssystems!
Sad to hear this. DOTX is widely used in my customer base. Esp. companies and organizations with centralized MS Office template folders or terminal servers use them a lot.
jakobssystems
Postby nypateffill4817 » Mon Apr 16, 2018 10:09 am
How to define the "Normal" default style to another value than Font:"Arial" Size:11 if there is no possibility to define a default template file (like the Normal.dotx in Word) ?
By looking on github, it seems that the default style is hardcoded in the source code.
If there a way to change the default style for all new documents ?
nypateffill4817
Postby Maxim » Thu Apr 19, 2018 12:12 pm
Hello nypateffill4817!
If you replace docx template file with another you need you will be able to create a file with needed parameters.
/var/www/onlyoffice/documentserver-example/public/samples/
There you will find - new.docx new.pptx new.xlsx sample.docx sample.pptx sample.xlsx files. You will need to change file new.
