Document comments author uneditable?
Postby Nalaurien » Mon May 08, 2017 1:52 am
create a spreadsheet in xlsx format.
enter some data into the sheet.
add comment to sheet via left menu.
comment appears with author mitchell hamish.
I have no idea who that is.
open document info via left menu.
open spreadsheet info via left menu.
only thing here is document name.
am i missing something? anyone have an idea whats going on here?
Nalaurien
Re: Document comments author uneditable?
Postby Maxim » Wed May 10, 2017 7:52 am
Hello Nalaurien!
Please check up from what user did you comment the document?
Also you can attach screenshot for more detailed discription of the issue.
Postby bentalarico » Wed Jun 14, 2017 5:34 pm
I too am getting this in the comments. When I go to make a comment, it is always attributed to Mitchell Hamish as the author. How do we change this? (I'm using KDE Neon, which is based off Ubuntu 16.04)
bentalarico
Postby Maxim » Thu Jun 15, 2017 6:11 am
Hello bentalarico!
Specify please version of Onlyoffice (Community Server, Document Server), instruction you followed to install Onlyoffice. Did you try to comment using differrent users? Is the same result?
Postby Merc » Thu Jun 15, 2017 10:39 pm
Interesting but not seeing this on CE server running on Ubuntu 16 LTS and latest Docker images (updated yesterday). Any other info?
Merc
