Macro lost in Onlyoffice
Postby NI3 » Sat Apr 22, 2017 2:00 pm
I uploaded a .doc file with some macros in it. After editing i downloaded the file and observed that the macros were missing. Is there a way to stop this loss?
NI3
Re: Macro lost in Onlyoffice
Postby Maxim » Mon Apr 24, 2017 7:46 am
Hello NI3!
Unfortunately there is no way. We cannot execute visual basic in browser ;) .
Postby tavinus » Wed Dec 13, 2017 7:41 pm
Hi, I guess his question is about being destructive, not about running the macro.
And I was wondering the same.
Even though the browser cannot execute VB, there should be no reason to REMOVE the macro from the document right?
It should stay there so it can be executed when using a desktop version later.
There could be other ways of executing VB as well (cross-compiling to JS for example).
Is there a way to make it non-destructive?
So it won't delete the macro contents from the file?
Also, can we do macros in some other language? (JS?)
tavinus
Postby Maxim » Fri Dec 15, 2017 8:08 am
Hello tavinus!
Yes and macros support is on testing period now.
I hope we will implement it into Onlyoffice Document Server soon.
Postby poplee » Mon Mar 19, 2018 5:57 am
That is good.
Is there any timeline, hope it asap.
poplee
Postby Maxim » Mon Mar 19, 2018 7:32 am
Hello poplee!
Unfortunately i cannot say
Users browsing this forum: Bing [Bot] and 1 guest
