Edit the document with the type: "mobile"
Postby dataprius » Wed Apr 12, 2017 5:51 pm
With this configuration
config =
"type": "mobile",
"document": {
"permissions": {
"edit": true
"editorConfig": {
"callbackUrl": ".....",
"mode": "edit",
When you open a document, onlyoffice does not allow you to edit it. Instead, with the type: "desktop" option you can edit it perfectly.
As it says in the documentation
What is missing?
I have the Document Server 4.3 version.
Thanks in advance.
Re: Edit the document with the type: "mobile"
Postby Maxim » Thu Apr 13, 2017 7:10 am
Hello dataprius!
We have detected the bug! Thank you for your error notification!
We will fix it in ver. 4.3.2!
