Old MS Office extensions prohibit savings
Postby globber » Thu Apr 06, 2017 1:03 pm
I just came to the fact that our installation of ONLYOFFICE does not save Documents successfully, if they have the old MS Office extensions *.doc, *.xls oder *.ppt.
Anyway, if you rename them and add an "x" to the extension they save successfully.
Best regards
Globber
ONLYOFFICE integrated Document Server
Architecture: amd64
Version: 4.3.3-4
globber
Re: Old MS Office extensions prohibit savings
Postby Maxim » Thu Apr 06, 2017 2:20 pm
Hello globber!
OnlyOffice doesn't support saving of old formats like *.doc, *.xls or *.ppt. After opening such format you can save the file docx, xlsx or pptx only. OnlyOffice saves documents absolutely successfully.
Postby globber » Thu Apr 06, 2017 2:36 pm
Thank you for your advice :P
Best regards
Globber
Architecture: amd64
Version: 4.3.3-4
globber
Users browsing this forum: iteng.jorgerodriguez and 2 guests
