Document not loading in Browser editor, only download popup
Postby muhsin » Thu Mar 02, 2017 3:53 pm
Dear All,
I installed Document Server Community edition Version 8.9.2.27 today on my Ubuntu 14 Desktop.. The problem is when i click any (default) document, its not loading in Browser editor, instead of that Download pop up window showing..i tried in Firefox and chrome also...
I have installed Document Server also in another Ubuntu 14 machine..when i loading its url in browser its just showing like a home page saying "Document Server is running" thats it
Can anyone one help me please ..!!!?i am new to this
muhsin
Re: Document not loading in Browser editor, only download po
Postby Maxim » Fri Mar 03, 2017 6:36 am
Hello muhsin!
You have installed Document Server only! Also there must be installed Community Server. Please reinstall Community Edition using this instruction.
Postby muhsin » Fri Mar 03, 2017 5:15 pm
Dear Maxim,,
thank you for your reply....
Actually I had already installed Document Server Community edition Version 8.9.2.27 itself in one PC by using http://helpcenter.onlyoffice.com/server ... lingDebian ..but when i faced Documents not loading in Browser issue i have installed Document Server Only in another PC by using http://helpcenter.onlyoffice.com/server ... ation.aspx but its home page showing only "Document Server is running"
message ...
Do i need to connect both Servers together ..!!??
Thanks in Advance
muhsin
Postby muhsin » Fri Mar 03, 2017 5:56 pm
Dear Maxim,
Thanks for your reply
When i trying Community Server installation from the url you provided the script ending saying "The following ports must be open: 80" while executing command bash opensource-install.sh -md "yourdomain.com"
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 32454 100 32454 0 0 5674 0 0:00:05 0:00:05 --:--:-- 7721
I have already opned all ports in that PC.. and no more firewall restriction
Any idea...!!!??
muhsin
Postby muhsin » Sun Mar 05, 2017 7:52 am
Maxim wrote:Hello muhsin!
Dear Maxim,
its saying port must be opened : 80 while installing
muhsin
Postby Maxim » Mon Mar 06, 2017 7:17 am
Hello muhsin!
The following ports must be opened for successful installation: 80 and 443. If you choose to install the Mail Server, port 25 has got to be opened. Type the following commands to check which ports are listening on the network:
netstat -anltp | grep «LISTEN»
netstat -tulpn
netstat -tulpn | grep :80
If you installed Community and Document Servers for Linux use this instruction to connect them.
If you installed Community Edition please specify OS on the server. Check which ports are opened.
Use docker ps command to check containers you've installed and assigned ports to containers.
And describe your issue in details please if Community Edition doesn't work.
