Image resizing bug (presentations): Aspect incorrect
Postby mus » Mon Feb 13, 2017 10:06 am
I drag&drop an image into a presentation, then try to rescale it with "erweiterte Einstellungen des Bildes" (extended image properties?) right-click menu.
The chain-icon, indicating that aspect ratio should be locked, is clicked.
If i now enter any value for "width", then "Height" is automatically adjusted.
BUT the aspect is wrong. It seems to be 1:1 by default, even when the picture is a different aspect. Suddenly i have a square image.
I have to click the button "Standardgröße" once for the dialog to take the correct aspect into account.
looks like the aspect value is just not calculated as the dialog gets initialised.
mus
Re: Image resizing bug (presentations): Aspect incorrect
Postby Maxim » Mon Feb 13, 2017 10:15 am
Hello mus!
I tried to reproduce your issue but i have no luck. It would be nice to attach screenshot.
Postby mus » Mon Feb 20, 2017 4:13 pm
1. open a new empty presentation.
2. drop in a jpg file
3. open "erweiterte Einstellungen". Note the image is 16.5 x 22cm and the aspect lock is on:
Screen Shot 2017-02-20 at 5.08.04 PM.jpg (58.84 KiB) Viewed 1156 times
4. now change "Breite" (Width) to "10"
5. as soon as you press tab, "Höhe" (Height) is also set to 10 when it should actually be set to 13.3
Screen Shot 2017-02-20 at 5.11.17 PM.png (16.85 KiB) Viewed 1156 times
This behavior does not happen when you click "Standardgröße" before you change "Breite".
I used onlyoffice 8.9.2.19
mus
Postby mus » Mon Feb 20, 2017 4:15 pm
i tried to reproduce this error in the new desktop editor 4.2.2. (139) and there it seems to work properly!
mus
Postby Maxim » Tue Feb 21, 2017 7:11 am
Hello mus!
I'm glad to hear it!
