Switching Co-editing Mode
Postby shippeli » Mon Dec 05, 2016 2:06 pm
i use a docker document server and integrate the editor with PHP. I wonder how to switch Co-editing Mode. As described in https://helpcenter.onlyoffice.com/ONLYO ... tings.aspx this feature should also be available in non paid version of onlyoffice. But i miss this option in advanced settings in the editor.
Another Question would be how to set the mode "fast" as default value programatically.
Thanks in advance!
shippeli
Re: Switching Co-editing Mode
Postby Maxim » Tue Dec 06, 2016 8:34 am
How to switch Co-editing Mode you can see here
Concerning to the mode "fast", it is used by default. If autosave = false than "fast" mode is turned off.
Postby shippeli » Thu Dec 15, 2016 9:31 am
Hi Maxim,
thanks for your reply. Unfortunately it still does not work. I did not change the coediting mode and autosave is on, although changes are shown only after hitting strg+s.
Accordingly the option is not shown in doceditor GUI (file -> advanced settings).
I tested it again with the latest document server docker image (just some minutes ago).
Thanks in advance!
shippeli
Postby Pavel.Lobashov » Fri Dec 16, 2016 10:49 am
Hi, can you attach a screenshot of Settings, and post an editor config json.
Pavel.Lobashov
Postby shippeli » Tue Dec 20, 2016 11:04 am
Here is the screenshot
and the config
            docEditor = new DocsAPI.DocEditor("iframeEditor",
                    width: "100%",
                    height: "100%",
                    type: "<?php echo ($_GET["action"] != "embedded" ?  "desktop" : "embedded") ?>",
                    documentType: "<?php echo getDocumentType($filename) ?>",
                    document: {
                        title: fileName,
                        url: "<?php echo $fileuri ?>",
                        fileType: fileType,
                        key: "<?php echo getDocEditorKey($fileuri) ?>",
                        vkey: "<?php echo getDocEditorValidateKey($fileuri) ?>",
                        info: {
                            author: "Me",
                            created: "<?php echo date('d.m.y') ?>"
                        permissions: {
                            edit: true,
                            download: false
                    editorConfig: {
                        mode: 'edit',
                        lang: "en",
                        callbackUrl: "<?php echo getCallbackUrl($filename) ?>",
                        embedded: {
                            saveUrl: "<?php echo $fileuri ?>",
                            embedUrl: "<?php echo $fileuri ?>",
                            shareUrl: "<?php echo $fileuri ?>",
                            toolbarDocked: "top"
                    events: {
                        'onReady': onReady,
                        'onBack': <?php echo ($_GET["action"] != "embeded" ?  "onBack" : "undefined") ?>,
                        'onDocumentStateChange': onDocumentStateChange,
                        'onRequestEditRights': onRequestEditRights,
                        'onSave': onDocumentSave,
                        'onError': onError
Thanks in advance
shippeli
Postby Pavel.Lobashov » Tue Dec 20, 2016 1:47 pm
shippeli wrote:Here is the screenshot
Seems you have some kind of old version of DocumentServer, could you tell exactly the version of package.
Like `dpkg -l | grep onlyoffice` inside docker
Pavel.Lobashov
Postby shippeli » Mon Jan 02, 2017 9:26 am
Sorry for the delay and a happy new year :)
I checked the document servers version and it gives me 3.0.0-99. Curious. I supposed that the Docker image pulls the current source code?!
I try it again with document server version 4.x
shippeli
Postby Maxim » Mon Jan 02, 2017 12:46 pm
I hope you have enabled Co-editing Mode....
Postby Pavel.Lobashov » Mon Jan 02, 2017 4:40 pm
shippeli wrote:Sorry for the delay and a happy new year :)
Try `docker pull onlyoffice/documentserver:4.2.3.5` - this is current stable release
Pavel.Lobashov
Postby shippeli » Tue Jan 03, 2017 2:18 pm
Allright, latest Document Server solved all my problems ;)
shippeli
Next
