Certain characters appearing as squares
Postby vprocopan » Tue Nov 08, 2016 2:16 pm
Hello.
Installed Community Edition Docker Version.
The language is Romanian.
Although the fonts installed in the system seam to support it, some of them are appearing correctly and two types are not
The unicode characters are U+0218 U+0219 U+021A U+021B
This seems to be the case with all of the fonts installed except DejaVu
Please help, thanks in advance.
vprocopan
Re: Certain characters appearing as squares
Postby Maxim » Wed Nov 09, 2016 12:52 pm
Font Arial (by default in OnlyOffice) you used in screenshot can be incomplete and not all characters can be displayed. Try to find the complete Arial font and add it to OnlyOffice following instructions
Postby brunogm » Thu Dec 08, 2016 6:26 pm
Maxim wrote:Hello!
I also have this problem but with the Enter and Backspace keys, a square appears everytime I press one of those keys.
Do you have any idea why is that?
brunogm
Postby Maxim » Fri Dec 09, 2016 10:31 am
brunogm wrote:
Maxim wrote:Hello!
Does it happen to all fonts or specified (Arial only for example)? Is the same result if you use on-screen board?
