Html Controls and Bookmark
Postby mukunthv » Mon Oct 24, 2016 1:52 pm
Hello I would like to know if html controls like input txt, drop-down list, bookmarks can be created using the document editor?
mukunthv
Re: Html Controls and Bookmark
Postby karthikkumarstp » Fri Mar 03, 2017 6:54 am
We are having similar requirement - Currently when docx file has bookmark and when you edit using onlyOffice, those bookmarks are removed. Also is there any way to retain content controls that exist in docx.
karthikkumarstp
Postby Maxim » Fri Mar 03, 2017 1:10 pm
Document editor supports html controls for opening file, but not for saving controls.
Unfortunately there is no way to retain content controls.
Postby dcolaco » Thu Apr 20, 2017 4:34 pm
I'm having a simular problem, with DocumentEditor after editing file the following happens:
MergeFields are kept in the file as original - ok
Word BookMarks are lost after editing - not ok
Any ideia why only word bookmarks are lost aftetr editing?
dcolaco
