Print DOC with comments and history versions
Postby kurdeno » Mon Oct 24, 2016 6:02 am
it is possible to print documents with all comments added to this doc and/or history versions, it's mean I want print doc with all versions when it's marked collors who add or change something in text.
thanks.
kurdeno
Re: Print DOC with comments and history versions
Postby Maxim » Mon Oct 24, 2016 12:05 pm
Sorry to say but it is not possible to print documents with comments or history versions of file. You can see and use comments in online ONLYOFFICE only. If you want someone to see comments to a document please use "Share" button. Also, you can make a screenshot of document with comments and history on your PC if it is necessary and than print the saved picture.
Postby kurdeno » Wed Oct 26, 2016 1:56 pm
I tought so,
thank you.
kurdeno
Users browsing this forum: Baidu [Spider] and 2 guests
