Default fonts for missing fonts?
Postby keepo » Fri Sep 23, 2016 12:42 am
Document Server Version: docker
I've installed all fonts from my windows but onlyoffice can't find the correct one.
fc-list shows the fonts has been installed, Deng.ttf: DengXian,等线:style=Regular
And I can find "DengXian" in fonts drop-down list.
However, the fonts used in my docx file is called "等线", rather than "DengXian". I think they are same fonts.
Is there a way to fix this or I can specify default fonts for missing fonts like openoffice/libreoffice do?
Thank you.
keepo
Re: Default fonts for missing fonts?
Postby Eugenie » Tue Sep 27, 2016 3:21 pm
1. First of all, please try to follow the instructions below:
https://helpcenter.onlyoffice.com/serve ... fonts.aspx
2. If it does not help, please send us .log files of font installation and the font file itself as we can detect the issue.
Eugenie
Postby keepo » Thu Sep 29, 2016 11:40 pm
Eugenie wrote:Hello,
Thanks for reply, I have no trouble installing fonts, and I can use that fonts.
The problem is document server cannot recognized that fonts. You can manually choose that fonts but not by default, my guess is linux using a different alias than windows?
Where should I send the fonts? It's larger than 10mb.
keepo
Postby Eugenie » Fri Sep 30, 2016 8:43 am
Please send them to support@onlyoffice.com
Eugenie
