Download as docx/odt -> margins gone
Postby thedonsolo » Fri Jul 22, 2016 10:44 pm
A simple image says it all, what can i do about this?
Page size = US Letter
Margins = US Normal
thedonsolo
Re: Download as docx/odt -> margins gone
Postby Eugenie » Mon Aug 08, 2016 1:37 pm
This issue is detected and our developers are working on its solution.
Eugenie
Postby iwkse » Wed Oct 26, 2016 9:38 am
Hi, I'm facing the same issue with the new 4.1.5 version. I didn't have such problems in the version 3.
There are also problems with corrupting files (for example editing odt files, seems to break the mimetype making it unreadable)
There are other issues also with text boxes, with odt and doc they disappear but docx keeps it.
I'm testing with the version 4.1.5, I'd be glad to be informed if there's some fixes for that or work arounds.
iwkse
Postby cpotter » Thu Dec 22, 2016 8:22 am
Facing same very annoying issue with LibreOffice.
The problem is the document.xml of the .docx archive. With did not have the time to go further (the margins are not in the right order but this should not be the problem)
DOCX Saved by Onlyoffice
<w:pgMar w:top="1134" w:right="1134" w:bottom="1134" w:left="1134" w:gutter="0" w:header="0" w:footer="0"/>
<w:pgBorders w:display="allPages" w:offsetFrom="page" w:zOrder="front" >
<w:bottom w:color="000000" w:space="0" w:sz="4" w:val="none" /><w:left w:color="000000" w:space="0" w:sz="4" w:val="none" />
<w:right w:color="000000" w:space="0" w:sz="4" w:val="none" /><w:top w:color="000000" w:space="0" w:sz="4" w:val="none" />
</w:pgBorders><w:cols w:num="1" w:sep="0" w:space="1700" w:equalWidth="1" ></w:cols><w:docGrid w:linePitch="360"/>
</w:sectPr></w:body></w:document>
Original DOCX
<w:pgMar w:left="1134" w:right="1134" w:header="0" w:top="1134" w:footer="0" w:bottom="1134" w:gutter="0"/>
<w:pgNumType w:fmt="decimal"/>
<w:formProt w:val="false"/><w:textDirection w:val="lrTb"/>
In our point of view this is a OnlyOffice bug but also a LibreOffice one (because opening such file works for us in Office and WPS)
I don't see also a GIT issue number
Best
Chris
cpotter
Postby cpotter » Fri Feb 03, 2017 11:38 am
Eugenie wrote:Hello,
Please can we have an update on this issue and the link to it in git ?
Thanks
Christopher
cpotter
Postby Maxim » Fri Feb 03, 2017 12:27 pm
Please specify what exactly version of Document Server do you use?
