Error editing file with the PHP example
Postby luis.mas » Wed Aug 26, 2015 9:03 am
Hi everyone,
I've installer OnlyOffice Document Server using docker without problems. In fact, I can access Docker IP and use Document Server and everything works fine.
I'm currently developing an integration with another application developed in PHP. So I downloaded the PHP example, configured it and I'm getting an error. Can you help me? Thanks!!! :cry:
These are the steps I've followed to make the things work:
1. Download de PHP example zip file from here: https://api.onlyoffice.com/app_data/PHP%20Example.zip
2. Configure an Apache VirtualHost with the URL http://onlyofficedemo.com
3. Modify /etc/hosts file to add the URL to 127.0.0.1
4. Uncompress it and modify the config.php file with my configurations (192.168.59.103 is the Docker IP and 8080 is the Docker mapped port):
<?php
define('WEB_ROOT_URL', 'http://onlyofficedemo.com');
$GLOBALS['FILE_SIZE_MAX'] = 5242880;
$GLOBALS['STORAGE_PATH'] = "";
$GLOBALS['MODE'] = "";
$GLOBALS['DOC_SERV_VIEWD'] = array(".ppt",".pps",".odp",".pdf",".djvu",".fb2",".epub",".xps");
$GLOBALS['DOC_SERV_EDITED'] = array(".docx",".doc",".odt",".xlsx",".xls",".ods",".csv",".pptx",".ppsx",".rtf",".txt",".mht",".html",".htm");
$GLOBALS['DOC_SERV_CONVERT'] = array(".doc",".odt",".xls",".ods",".ppt",".pps",".odp",".rtf",".mht",".html",".htm",".fb2",".epub");
$GLOBALS['DOC_SERV_TIMEOUT'] = "120000";
$GLOBALS['DOC_SERV_STORAGE_URL'] = "http://192.168.59.103:8080/FileUploader.ashx";
$GLOBALS['DOC_SERV_CONVERTER_URL'] = "http://192.168.59.103:8080/ConvertService.ashx";
$GLOBALS['DOC_SERV_API_URL'] = "https://doc.onlyoffice.com/OfficeWeb/apps/api/documents/api.js";
$GLOBALS['DOC_SERV_PRELOADER_URL'] = "https://doc.onlyoffice.com/OfficeWeb/apps/api/documents/cache-scripts.html";
$GLOBALS['ExtsSpreadsheet'] = array(".xls", ".xlsx",
                                    ".ods", ".csv");
$GLOBALS['ExtsPresentation'] = array(".pps", ".ppsx",
                                    ".ppt", ".pptx",
                                    ".odp");
$GLOBALS['ExtsDocument'] = array(".docx", ".doc", ".odt", ".rtf", ".txt",
                                ".html", ".htm", ".mht", ".pdf", ".djvu",
                                ".fb2", ".epub", ".xps");
if ( !defined('ServiceConverterMaxTry') )
    define( 'ServiceConverterMaxTry', 3);
if ( !defined('ServiceConverterTenantId') )
    define( 'ServiceConverterTenantId', '');
if ( !defined('ServiceConverterKey') )
    define( 'ServiceConverterKey', '');
5. Access to http://onlyofficedemo.com and it shows the upload form
6. Upload one .doc file and it uploads ok
7. Click in "Edit" button and finnaly I get this error:
URL:
https://doc.onlyoffice.com/CanvasService.ashx
Parameters:
{"id":"3811764809","userid":"uid-1440579166276","format":"docx","vkey":"d08xNTAvQmxkcjA5VThzbnh1VU1ER3NneWcrYkZMVWlnSFRjY2ZEMXpzdz0_eyJleHBpcmUiOiJcL0RhdGUoMTQ0MDU3OTE2NDExOSlcLyIsImtleSI6IjM4MTE3NjQ4MDkiLCJrZXlfaWQiOiIiLCJ1c2VyX2NvdW50IjowLCJpcCI6IjEyNy4wLjAuMSJ90","editorid":0,"c":"chopen"}
Error:
{"type":"err","data":"-81"}
luis.mas
Re: Error editing file with the PHP example
Postby luis.mas » Thu Aug 27, 2015 7:25 am
Ok so I found the error and apply the solution. The problem was the config file: the server converting and server api URL's where pointing to onlyoffice.com not to my local server.
You can close the post! :)
luis.mas
