spell-checking
spell-checking
Postby edgarjpgoncalves » Mon Feb 02, 2015 7:31 pm
OnlyOffice installed a server and documents the spelling checker does not work!
spell
In the settings does not appear the framework for selecting the corrector
edgarjpgoncalves
Re: spell-checking
Postby Dean » Wed Feb 18, 2015 2:34 pm
Could you please check the service ONLYOFFICE Online Editors Spellchecker Service to be started?
Re: spell-checking
Postby edgarjpgoncalves » Fri Feb 20, 2015 12:27 am
is started
Imagem sem título.png (162.37 KiB) Viewed 4022 times
edgarjpgoncalves
Re: spell-checking
Postby edgarjpgoncalves » Fri Feb 20, 2015 9:54 am
the editor settings not appear marking the spell checker
edgarjpgoncalves
Re: spell-checking
Postby onlyofficeguy » Thu Jun 04, 2015 7:05 pm
I have the same issue.. has this been resolved?
thanks
onlyofficeguy
Re: spell-checking
Postby Dean » Fri Jun 05, 2015 6:34 am
onlyofficeguy wrote:I have the same issue.. has this been resolved?
thanks
Could you please specify, what is the ONLYOFFICE version you've installed and the installation method?
Re: spell-checking
Postby marcopinero » Tue Mar 28, 2017 12:09 pm
I cannot make spellchecking to work. I have lastest documentserver docker. How can I make auto-spellchecking to work while writing?
marcopinero
Re: spell-checking
Postby Maxim » Tue Mar 28, 2017 2:41 pm
marcopinero wrote:I cannot make spellchecking to work. I have lastest documentserver docker. How can I make auto-spellchecking to work while writing?
Please specify is spellchecking option enabled?
