Text manipulation with PHP
Postby Michel » Fri Oct 12, 2018 1:34 pm
Hi, I'm new here, and I'm not sure where to look.
I'm Brazilian, so the difficulty increases a little.
I'm in a project, and I want to use the OnlyOffice Document Editor, so people can assemble the documents on the platform, but I need to save the data (text) in my database. For this I am using PHP language.
I did not do any tests, because I do not know if it is possible to do this. (manipulate data with php and inject into onlyoffice).
I would like to know if you have any manuals or support material that I can use, or if someone could, please guide me in this task.
Thank you !
Michel
