OnlyOffice Desktop and Webdav network share
Postby cpotter » Wed Oct 10, 2018 3:07 pm
Hi everyone,
We tried to use OnlyOffice Desktop using a file on a Webdav windows network share. Opening was not a issue however it creates a temporary folder ie "96c3bab2-f48d-44c9-be34-7e59dee417d5" and this folder is not in the local Windows temp folder ie "C:\Users\username\AppData\LocalLow\Temp" and it should be there and not in the same directory than the file.
Can we create a feature/bug fix request ?
Best,
Ch.Potter
cpotter
