Config Document Server API to get from Community Server
Postby coisox » Fri Sep 28, 2018 8:57 am
I've integrated Document Server and Community Server successfully (maybe). When I call CS API to get the edit link, it return:
http://cs.com/products/files/doceditor.aspx?fileid=99&doc=bDhxcHgrbHJCeisrZXM4VzlEei9PRFNVRUp3cWlJS2dyOVpXUVNOOHNicz0_Ijk5Ig2
My problem is, the URL for CS mustn't be public. Only the DS URL can be made public. So I assume using the CS API will always return URL from CS server (not configurable?).
Now I have to switch from using CS API to DS front end API (which I hope can cater my need to edit, download, delete, create folder). I can't figure whats the correct URL & callbackUrl since I don't know the physical file URL:
var docEditor = new DocsAPI.DocEditor("placeholder", {
   "document": {
      "fileType": "docx",
      "key": "Khirz6zTPdfd7",
      "url": "http://cs.com/products/files/doceditor.aspx?fileid=99" <-- this is wrong but what?
   "documentType": "text",
   "editorConfig": {
      "callbackUrl": ""  <-- no idea at all
coisox
