Formula gets cut off
Postby jenson » Wed Sep 26, 2018 1:04 pm
we have some complex Microsoft Excel files with complex formulas.
If we upload the file to our cloud and try to open the calculation with the onlyoffice editor some formulars get cut off and the whole calculation is faulty.
Would be awesome if the formular would work or atleast wont get cut off if the editor cant use it so the file wont get corrupted.
Example (german formula):
Excel formula: =SUMMENPRODUKT(TEILERGEBNIS(9;INDIREKT(T$1&ZEILE(T$9:T$160)))*($CA$9:$CA$160="x"))*POTENZ(($I$163+1);T$5)
onlyoffice formula: =($CA$9:$CA$160="x")*POTENZ(($I$163+1);T$5)
I recently posted this issue but the post got delted after it was approved.
Thank you.
jenson
Re: Formula gets cut off
Postby Carl » Thu Sep 27, 2018 12:32 pm
Can you please specify what ONLYOFFICE solution you are using?
Postby jenson » Fri Sep 28, 2018 6:42 am
I am running the onlyoffice Document Server Community Edition to integrate into ownCloud.
ownCloud App version 2.0.1
onlyoffice version 5.1.0 CE
jenson
Postby Carl » Wed Oct 03, 2018 1:27 pm
Can you please send us an example file where the issue can be seen? Also please specify OS of the server where DS is installed and its type of installation (docker, deb/rpm).
Postby jenson » Thu Nov 22, 2018 8:46 am
Hello Carl,
sorry the late reply. You can download the file here: https://www.file-upload.net/download-13 ... 4.zip.html
See cell T164.
In Excel the formular is "=SUMMENPRODUKT(TEILERGEBNIS(9;INDIREKT(T$1&ZEILE(T$9:T$160)))*($CA$9:$CA$160="x"))*POTENZ(($I$163+1);T$5)"
after the file is opened in onlyoffice Document Server (over ownCloud) the formular is cut to "=($CA$9:$CA$160="x")*POTENZ(($I$163+1);T$5)"
Versions:
ownCloud 10.0.10
ONLYOFFICE ownCloud App 2.0.3
Spreadsheet Editor 5.2.3 CE
Thanks.
jenson
