Online editing and saving docx ending in a corrupt file
Postby diffdev » Wed Sep 05, 2018 9:50 am
we just realized that by editing and saving any docx document ruins its descriptor. The header and footer xml is populated with an "<a:graphicFrameLocks>" node which makes Word unable to open it...
Could this be an error on our end? Did anyone face the same before?
Regards,
Janos
diffdev
Re: Online editing and saving docx ending in a corrupt file
Postby Maxim » Thu Sep 06, 2018 3:50 pm
Hello diffdev!
Unfortunately but there is not enough information. Is it possible to get this file to analyze and it would be great if you inform us version of Word you used to open the file.
Users browsing this forum: Exabot [Bot] and 3 guests
