numeric keypad dot as a decimal point separator character
Postby hedrix » Sat Jul 14, 2018 10:32 am
I am trying to configure onlyoffice with nextcloud and I would need to know if it is possible to configure it so that when I press the point of the numeric keypad a decimal comma separator appears in spreadsheet.
I am using DocumentServer and the local language configuration is Spanish in NextCloud and OnlyOffice
Thank you
Best regards
hedrix
Re: numeric keypad dot as a decimal point separator characte
Postby Maxim » Mon Jul 16, 2018 10:05 am
Hello hedrix!
I suppose it is not possible to configure keypad. There is no keyboard customization in Onlyoffice.
