Mobile Editor
Mobile Editor
Postby cyam » Wed Jul 04, 2018 8:43 am
https://helpcenter.onlyoffice.com/mobil ... index.aspx
As the information mentioned in above link, the mobile can also view and edit documents, will it be viable if i add some other functions to the mobile editor, such as collaboration>Track changes?
Many Thanks!!
cyam
Re: Mobile Editor
Postby Maxim » Thu Jul 05, 2018 10:37 am
Hello cyam!
It is going to be implemented in mobile app. (next release i suppose)
Re: Mobile Editor
Postby cyam » Fri Jul 06, 2018 3:56 am
Maxim wrote:Hello cyam!
how about the online editor that open in mobile browser, will that be supported too?
cyam
Re: Mobile Editor
Postby Maxim » Fri Jul 06, 2018 6:28 am
Hello cyam!
If you open in mobile browser Onlyoffice you should see track changes.
