Plugins activated on load?
Postby smithj » Thu Apr 19, 2018 8:52 pm
Is there a way to make plugins available on document load? I'd like it so that the plugin will be active without going to the menu and enabling them first, I'd like them to just be on and available from the beginning.
smithj
Re: Plugins activated on load?
Postby Maxim » Thu Apr 26, 2018 1:40 pm
Hello smithj!
Adding a plugin to the server editors
There are two ways to add the plugins to ONLYOFFICE Document Server installation:
Put the folder with the plugin code to ONLYOFFICE Document Server folder depending on the operating system:
For Linux - /var/www/onlyoffice/documentserver/sdkjs-plugins/.
For Windows - %ProgramFiles%\ONLYOFFICE\DocumentServer\sdkjs-plugins\.
The plugins will be available to all the users users of ONLYOFFICE Document Server. No service restart is required.
Or edit the Document Server config to add the following lines:
var docEditor = new DocsAPI.DocEditor("placeholder", {
    "editorConfig": {
        "plugins": {
            "autostart": [
                "asc.{0616AE85-5DBE-4B6B-A0A9-455C4F1503AD}",
                "asc.{FFE1F462-1EA2-4391-990D-4CC84940B754}",
            "pluginsData": [
                "https://example.com/plugin1/config.json",
                "https://example.com/plugin2/config.json",
Where the example.com is the name of the the server where document manager and document storage service are installed and the plugins are placed. See the How it works section to find out more on Document Server service client-server interactions.
