Turning on iteration counting
Postby Jedrzej » Fri Mar 02, 2018 7:19 am
<Spreadsheet>
I have a problem with iteration counting in spreadsheet. Normally I can turn it on in case of super formula. Can I do it in Onlyoffice calc?
In attachment there is an example from googledocs (how usually i can change it).
Everything is becouse of formula wich I have to use:
=IF(I4<>"";IF(OR(M4="";AND(N4<>FALSE;N4<>I4));NOW();M4);"")
more about it here: http://www.excelblog.pl/excel-timestamp ... -wkomorce/
Please help me to solve this problem.
Screen Shot 03-02-18 at 08.09 AM.PNG (34.09 KiB) Viewed 483 times
Jedrzej
Re: Turning on iteration counting
Postby Maxim » Wed Mar 07, 2018 10:19 am
Hello Jedrzej!
Unfortunately but Onlyoffice doesn't support iteration counting in spreadsheet.
This bug has been redirected to our developers. Hope the fix will be soon.
