Bug: Editing a presentation even if mode=view
Postby chinicuin » Thu Feb 15, 2018 9:10 pm
Hello.
I believe I found a bug while viewing a pptx presentation in mode=view.
When I open a pptx with mode=view I can't write on any text box, that is correct. But I try to write something, then I press click on the line border of the text box and press delete in my keyboard. After this, every time I press delete, the text keep appearing appended where I tried to write initially.
This happens only on Firefox 58.0.2, there is no problem when using Chrome 64.0.3282.167.
This is a common issue? I mean, others users have the same problem or is just me?
Thank you in advance for you response.
chinicuin
Re: Bug: Editing a presentation even if mode=view
Postby Maxim » Thu Feb 22, 2018 11:09 am
Hello chinicuin!
I just tried to repeat using your scenario, but have no luck. Everything is OK!
