Table resize in Presentation document
Postby dairaine » Tue Feb 06, 2018 4:10 pm
I experience a problem when I want to resize the whole size of a table in a presentation document. It is only possible to adjust the size of each line/column clicking on the intermediate horizontal or vertical lines. When I try to change the size of the table itself by clicking on the edges of the table, it only moves the table in the slide but it seems there is no way modify the table size.
Thanks for your help.
Laurent
dairaine
Re: Table resize in Presentation document
Postby Maxim » Wed Feb 07, 2018 8:40 am
Hello dairaine!
You are right, there is no way to modify the table size!
Postby bendhoward » Wed Mar 28, 2018 7:08 pm
Hm, does anyone feel like that's a problem? It makes tables effectively useless, and they're a pretty core component of many presentations...
bendhoward
Postby Maxim » Thu Mar 29, 2018 8:07 am
Hello bendhoward!
We will take your information into account!
