[SOLVED] terrible save bug
Postby urfausto » Sun Jan 28, 2018 4:28 pm
there is a huge bug that happens this way: when you have edited the open document, save it as pdf for example (exporting it to a different format from the actual being opened) and then hitting the quit button you are not asked to save the document in its original extension and format.
i have the latest desktop version installed on windows 7 x64
urfausto
Re: terrible save bug
Postby Maxim » Mon Jan 29, 2018 6:34 am
Hello urfausto!
Please specify original file was edited too, was it changed?
Postby urfausto » Mon Jan 29, 2018 11:33 am
yes sure: edited the original one then saved it as pdf in this case.
urfausto
Postby urfausto » Thu May 03, 2018 7:04 pm
anyone looked into it?
urfausto
Postby Maxim » Sun May 06, 2018 10:25 am
Hello urfausto!
I tried to reproduce your scenario but had no luck.
Postby urfausto » Wed Jul 04, 2018 6:58 pm
this bug has been fixed with the newest version!
cheers!
urfausto
Re: [SOLVED] terrible save bug
Postby Maxim » Thu Jul 05, 2018 10:38 am
:D
