No letters on presentation file
Postby misa.djalovic » Fri Dec 29, 2017 2:40 pm
I have a problem with editing presentation files. Document Editors opens these files with no letters. These files are generated using library called PHPPresentation. For other files Document Editor works fine. Did someone else have this kind of problems? When I take file and open it in PowerPoint and save them, document servers opens when fine as well. It seems that library we are using is causing these issues. any kind of assistance would be great! Thanks!
misa.djalovic
Re: No letters on presentation file
Postby Maxim » Sat Dec 30, 2017 8:04 am
Hello misa.djalovic!
Is there a chance to take a look at your presentation with no editing in PowerPoint? Original file i mean.
Postby misa.djalovic » Tue Jan 02, 2018 1:05 pm
misa.djalovic
Postby Maxim » Wed Jan 10, 2018 11:41 am
Thank you for provided information.
We will fix it.
