Document docx not saved
Postby sebastienbeausoleil » Sun Dec 10, 2017 3:09 pm
A document on which I worked since 1 hour didn't get saved and I lost all the work I've done since I opened the document.
I look in the document server log file and here are the 2 error that seam related with the problem since the timestamps match the last file versions that I found in nextcloud.
If you can help me to understand what I've done wrong, your welcome.
Thanks
[2017-12-09 19:47:11.033] [ERROR] nodeJS - changesError: docId = 194362_1512861797_2 Error: Syntax error, unrecognized expression: #status-chat-user-t.johnson@example.com3 Script: https://lool.example.com/2017-11-10-16-41/web-apps/apps/documenteditor/main/app.js Line: 9:16598 userAgent: Mozilla/5.0 (Windows NT 6.1; WOW64; Trident/7.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; NP06; .NET4.0C; .NET4.0E; GWX:DOWNLOADED; GWX:RESERVED; rv:11.0) like Gecko platform: Win32 StackTrace: Error: Syntax error, unrecognized expression: #status-chat-user-t.johnson@example.com3
   at e.error (https://lool.example.com/2017-11-10-16-41/web-apps/apps/documenteditor/main/app.js:9:16598)
   at e.tokenize (https://lool.example.com/2017-11-10-16-41/web-apps/apps/documenteditor/main/app.js:9:22722)
   at e (https://lool.example.com/2017-11-10-16-41/web-apps/apps/documenteditor/main/app.js:9:5674)
   at find (https://lool.example.com/2017-11-10-16-41/web-apps/apps/documenteditor/main/app.js:9:25311)
   at _onUsersChanged (https://lool.example.com/2017-11-10-16-41/web-apps/apps/documenteditor/main/app.js:36:20778)
   at M (https://lool.example.com/2017-11-10-16-41/web-apps/apps/documenteditor/main/app.js:8:10944)
   at Anonymous function (https://lool.example.com/2017-11-10-16-41/web-apps/apps/documenteditor/main/app.js:8:11148)
   at Anonymous function (https://lool.example.com/2017-11-10-16-41/web-apps/apps/documenteditor/main/app.js:8:4347)
   at c (https://lool.example.com/2017-11-10-16-41/web-apps/apps/documenteditor/main/app.js:11:13854)
   at t.Events.trigger (https://lool.example.com/2017-11-10-16-41/web-apps/apps/documenteditor/main/app.js:11:13121)
[2017-12-09 20:09:22.270] [ERROR] nodeJS - sendServerRequest error: docId = 194362_1512861797_2;url = https://intranet.example.com/index.php/apps/onlyoffice/track?doc=UyszM25kUUplWHk1MzV1YmlGaXNZc056Z0l0ZGVDYzZvY3VPTEtiYXNLWT0/eyJmaWxlSWQiOjE5NDM2MiwidXNlcklkIjoibS5zb3VyZGlmQGNlcmouY2EiLCJhY3Rpb24iOiJ0cmFjayJ9;data = {"key":"194362_1512861797_2","status":2,"url":"https://lool.example.com/cache/files/194362_1512861797_2_1265/output.docx/output.docx?md5=lBIFgp0QRVdS6Wja7VjcrA==&expires=1515460163&disposition=attachment&ooname=output.docx","changesurl":"https://lool.example.com/cache/files/194362_1512861797_2_1265/changes.zip/changes.zip?md5=5X6cRLuqpoJChIFVTXBLVw==&expires=1515460163&disposition=attachment&ooname=output.zip","history":{"serverVersion":"5.0.4","changes":[{"created":"2017-12-10 00:26:50","user":{"id":"j.smith@example.com","name":"j.smith@example.com"}},{"created":"2017-12-10 00:47:32","user":{"id":"t.johnson@example.com","name":"Tammy Johnson"}},{"created":"2017-12-10 00:48:35","user":{"id":"j.smith@example.com","name":"j.smith@example.com"}}]},"users":["j.smith@example.com"],"actions":[{"type":0,"userid":"j.smith@example.com"}],"lastsave":"2017-12-10T01:06:07.997Z","notmodified":false}^M
Error: Error response: statusCode:404 ;body:^M
{"message":"Files not found"}
    at Request._callback (/var/www/onlyoffice/documentserver/server/Common/sources/utils.js:269:18)
    at Request.self.callback (/var/www/onlyoffice/documentserver/server/Common/node_modules/request/request.js:186:22)
    at emitTwo (events.js:126:13)
    at Request.emit (events.js:214:7)
    at Request.<anonymous> (/var/www/onlyoffice/documentserver/server/Common/node_modules/request/request.js:1163:10)
    at emitOne (events.js:116:13)
    at Request.emit (events.js:211:7)
    at IncomingMessage.<anonymous> (/var/www/onlyoffice/documentserver/server/Common/node_modules/request/request.js:1085:12)
    at Object.onceWrapper (events.js:313:30)
    at emitNone (events.js:111:20)
sebastienbeausoleil
Re: Document docx not saved
Postby Maxim » Tue Dec 12, 2017 7:40 am
Hello sebastienbeausoleil!
According to the log app didn't find a file to save changes.
