Fulltext Search in Documents
Postby mario.stuck » Fri Nov 17, 2017 3:27 pm
Hi, we are just evaluating onlyoffice. We tried to search for documents, but the search doesn't find documents by test inside the documents.
Is this right? And could this be implemented?
Thanks for a short advise.
Mario
mario.stuck
Re: Fulltext Search in Documents
Postby Maxim » Tue Nov 21, 2017 7:50 am
Hello mario.stuck!
We really want to implement that feature into Onlyoffice. I suppose that there is a problem to implement it into SaaS version but i think we will implement it into Enterprise Edition. I cannot say when but we are working on it.
Postby hassan.mustafa » Wed Jan 24, 2018 6:25 am
Hi, i am working with onlyoffice document server installed on my local server successfully and everything is working great.
But is there any way to search documents by text inside the documents without opening a specific document? Is that possible in onlyoffice document server?
any help or suggestion will be appreciable.
thanks in advance.
hassan.mustafa
Postby Maxim » Mon Jan 29, 2018 10:41 am
Hello hassan.mustafa!
Unfortunately but for now this feature is not implemented into Onlyoffice. We really understand how it's important for users. I hope we will add this feature, but as i said above i cannot say when.
