Insert a custom string to the doc (where the cursor is)
Postby michaeldavidson » Thu Sep 28, 2017 6:15 pm
I'm trying to programatically add a string from a long list of a strings to the open document. The user would click a button next to that string and the string would be inserted into the doc at the place where the cursor is active.
I would really prefer not to create a plugin for each string because there are ~200 different ones, and I want the user to be able to press a button outside the doc editor.
Do I have to make a call to the API? I'm not seeing any callbacks I can hook a function into that I can call from the Window or anything.
I'm trying to do this in JS. Our page calls a PHP page thru JS, we COULD do this in PHP but I'd prefer a JS solution.
Our server is set up in PHP and I think we have the integration edition (I personally didn't do the integration).
Thanks.
michaeldavidson
Re: Insert a custom string to the doc (where the cursor is)
Postby Maxim » Fri Sep 29, 2017 10:57 am
Hello michaeldavidson!
Here is onlyoffice api, i hope it will help you.
Postby michaeldavidson » Mon Oct 02, 2017 3:16 pm
We have the integration edition and we've been using the API. Is there anyone who could help us with this?
michaeldavidson
