Chinese support questions.
Postby am_tony » Thu Aug 31, 2017 8:15 am
I found that the use of the revised function, can not correctly capture the Chinese input method input Chinese.
In addition to the support of the Chinese format there are some problems, for example, when the layout of the punctuation mark to the first of a line, the Chinese generally do not put a single punctuation on the first of a line.
am_tony
Re: Chinese support questions.
Postby Alexander_mb » Tue Sep 05, 2017 10:47 am
Hello am_tony,
Could you please describe the problem in more details for us to detect the reason (as much as possible). Please send us also screenshots, which illustrate the mentioned issue.
Alexander_mb
