How about the progress of Asia fonts support?
Postby Sraw3 » Fri Aug 11, 2017 7:28 am
Since May, your team declares that you started developing fonts support for Asia fonts.
Now it is August, how about the progress?
I think there are at least two features should be implemented:
1. Set the default converted font to a font which support Asia fonts(e.g. Chinese, Japanese) if there is no font matched.
2. Automatically change the input default font if the input font is an Asia font.
Thanks for reply.
Sraw3
Re: How about the progress of Asia fonts support?
Postby Alexander_mb » Tue Aug 15, 2017 1:14 pm
Hello Sraw3,
Our platform supports Asian fonts, but if the required fonts are presented in Document Server. Please note that improving of Asian fonts support is very difficult and it will take much time to improve that system. Our developers are keep working on it.
As for your suggestions, conversion of fonts would take a lot of time and make work with document very time-consuming, but our developers already provided with this information.
If you have faced any problem with the fonts, could you please describe it in more details. We could find an individual solution in particular situations.
Alexander_mb
