Problem parsing JSON in Chromium 59
Postby PurpleAlien » Thu Jun 22, 2017 11:35 pm
Hi all,
I'm running Onlyoffice Version 9.0.0.300. I recently updated Chromium on client side to version 59 (59.0.3071.104 developer build).
I'm seeing the following in the console, which prevents me to opening any document or folder:
Error parseJSON:
                  "entryType": "folder",
                  "access": 0,
                  "create_by_id": "9db9cd5e-cd54-11e6-a7a1-0242ac12000415/06/2017 00:3422/06/2017 22:18falseppt0,
                  "provider_key": "",
                  "provider_id": "",
                  "error": ""
files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1 Uncaught TypeError: Cannot read property 'entryId' of null
    at HTMLLIElement.<anonymous> (files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1)
    at Function.each (head-5YvgxlJ81lsF74KwR1f3YQ2.js?ver=9.0.0.300:2)
    at i.fn.init.each (head-5YvgxlJ81lsF74KwR1f3YQ2.js?ver=9.0.0.300:2)
    at Object.rt [as addRowHandlers] (files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1)
    at n (files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1)
    at e (files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1)
    at s (files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1)
    at Object.c (files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1)
    at Object.complete (files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1)
    at c (head-5YvgxlJ81lsF74KwR1f3YQ2.js?ver=9.0.0.300:2)
(anonymous) @ files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1
each @ head-5YvgxlJ81lsF74KwR1f3YQ2.js?ver=9.0.0.300:2
rt @ files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1
n @ files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1
e @ files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1
s @ files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1
c @ files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1
c @ head-5YvgxlJ81lsF74KwR1f3YQ2.js?ver=9.0.0.300:2
fireWith @ head-5YvgxlJ81lsF74KwR1f3YQ2.js?ver=9.0.0.300:2
b @ head-5YvgxlJ81lsF74KwR1f3YQ2.js?ver=9.0.0.300:2
(anonymous) @ head-5YvgxlJ81lsF74KwR1f3YQ2.js?ver=9.0.0.300:2
Error parseJSON:
                  "access": 0,
                  "create_by_id": "9db9cd5e-cd54-11e6-a7a1-0242ac12000427/02/2017 01:3116/03/2017 20:51trueLog0,
                  "provider_key": "",
                  "provider_id": "",
                  "error": ""
files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1 Uncaught TypeError: Cannot read property 'id' of null
    at HTMLAnchorElement.<anonymous> (files-Ra4sMIpuXwsVl52tbUKL2w2.js?ver=9.0.0.300:1)
    at HTMLUListElement.dispatch (head-5YvgxlJ81lsF74KwR1f3YQ2.js?ver=9.0.0.300:2)
    at HTMLUListElement.a.handle (head-5YvgxlJ81lsF74KwR1f3YQ2.js?ver=9.0.0.300:2)
Any ideas? It seems as if something is wrong in the "create_by_id" value. The error does not occur in FireFox (52.2.0) and I can open/edit files/folders just fine.
PurpleAlien
Re: Problem parsing JSON in Chromium 59
Postby Maxim » Thu Jun 29, 2017 11:13 am
Hello PurpleAlien!
We tried to reproduce the issue but had no luck. Please try to clean browser's cache.
Postby PurpleAlien » Fri Jun 30, 2017 5:50 pm
That was one of the fist things I tried, no luck.
Not sure what additional info I can give. The client browser is running on Gentoo Linux, but that shouldn't make a difference.
I'll see if I can gather more intel.
PurpleAlien
Postby Maxim » Mon Mar 19, 2018 10:25 am
Please try to reproduce it in Community Server ver.9.6
