unable to type in input when editing in iFrame in IE/Edge
Postby kaniansky » Tue Jun 13, 2017 8:32 am
User is unable to type anything inside an input on a page with iFrame with full access permissions using Internet Explorer or Edge (see attached sample html).
The frame has to be removed before the user can use the input
test.zip
(230 Bytes) Downloaded 37 times
kaniansky
Re: unable to type in input when editing in iFrame in IE/Edg
Postby Maxim » Tue Jun 13, 2017 9:19 am
Hello kaniansky!
How is this issue related to Onlyoffice?
Maybe you should use another browser.
Postby kaniansky » Tue Jun 13, 2017 11:26 am
This must be OnlyOffice issue as it only does not work when the user is editting the file.
All is working properly when only viewing the file, though the caret is still blinking in the editor even without a focus.
It seems that the OnlyOffice catches all keyboard events from parent window resulting in the text being inserted in the editor and not in the focused input.
kaniansky
Postby Maxim » Fri Jun 16, 2017 8:45 am
Hello kaniansky!
We have found a bug! Thank you for the information. Hope that we will fix it soon.
