Document Server Font Adding
ONLYOFFICE Open Source Version news
Postby proin » Sun Apr 19, 2015 4:28 pm
I think that document server is needed Font Adding Function for multi language supports.
Now I install docker packages at my server and It works well but non-english character is not disable to read and write.
I try to change the font by forced to change font by installing font to docker container and change AllFonts.js file.
Then I show that non-english character(in my case, Korean) is visible, but do not write.
I update this issue to github repo's issue tab.
Is there any function that you made functions for adding fonts to document server?
If you did, let me know what I do for adding fonts.
plz, reply my question.
thanks.
proin
Re: Document Server Font Adding
Postby Dean » Tue Apr 21, 2015 6:08 am
Return to ONLYOFFICE for *NIX
Users browsing this forum: Yahoo [Bot] and 2 guests
