Changing Port
IIS, Apache
Changing Port
Postby spectre216 » Thu Jun 08, 2017 11:55 pm
I know by default OnlyOffice runs on port 80/443. Is there a way to change this port so I can run it on a custom port? I am using the community server edition of OnlyOffice.
spectre216
Re: Changing Port
Postby Maxim » Tue Jun 13, 2017 9:05 am
Hello spectre216!
Installing Community Server integrated with Document and Mail Servers
You can run Onlyoffice on custom port but you need to delete all previous containers and follow steps. If you do not need Mail Server - skip this step. Like this
STEP 1: Create the 'onlyoffice' network
docker network create --driver bridge onlyoffice
STEP 2: Install Document Server
sudo docker run --net onlyoffice -i -t -d --restart=always --name onlyoffice-document-server \
    -v /app/onlyoffice/DocumentServer/data:/var/www/onlyoffice/Data \
    -v /app/onlyoffice/DocumentServer/logs:/var/log/onlyoffice \
    onlyoffice/documentserver
STEP 3: Install Community Server
sudo docker run --net onlyoffice -i -t -d --restart=always --name onlyoffice-community-server \
    -p 80:80 -p 5222:5222 -p 443:443 \
    -e DOCUMENT_SERVER_PORT_80_TCP_ADDR=onlyoffice-document-server \
    -e MAIL_SERVER_DB_HOST=onlyoffice-mail-server \
    onlyoffice/communityserver
-p 80:80 -p 5222:5222 -p 443:443 \ - this line for your custom ports
