reverse proxy: specific nginx proxy settings for onlyoffice?
IIS, Apache
Postby philm » Mon Sep 05, 2016 11:45 am
Hello
I managed to install onlyoffice in an ubuntu14 VM (KVM),and docker, with only doc+community services. Everything is fine (connections, editions, data mapping between VM and containers...) when the VM is on my public network.
But as soon as I put the onlyoffice VM behind my nginx reverse proxy, it hangs on editing documents (configuration, connection on FQDN and data are Ok). First I try to make it work only with http...
1) "public" net
10.0.0.3
("public" office on http)  -> Everything is OK   on http://10.0.0.3
10.0.0.2
(Reverse Proxy nginx)
2) behind reverse proxy (nat network)
10.0.0.2   <---------->             192.168.0.2
(Reverse Proxy nginx)                  |
"public net"                         |
CNAME server1.mydomain             192.168.0.3 ->  Ok
CNAME server2.mydomain             192.168.0.4 ->  Ok
CNAME ooffice.mydomain             192.168.0.5 -> http://ooffice.mydomain
/etc/nginx/sites-enables/myconf
server {
server_name server1.mydomain;
location / {
proxy_pass http://192.168.0.3/ ;
include includes/proxy.inc ;
server {
server_name office.mydomain;
location / {
proxy_pass http://192.168.0.5/ ;
my proxy.inc files
proxy_redirect off;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
Should I change some settings in my reverse-proxy nginx VM? ...or should I look at specific settings in my OnlyOffice VM/containers?
Thanks in advance,
Phil
philm
Re: reverse proxy: specific nginx proxy settings for onlyoff
Postby Alex » Mon Sep 05, 2016 3:12 pm
Could you please provide us with additional information about the issue, please describe what exactly happens.
Is there any ways t get access to the portal?
Feel free to sent the info to server@onlyoffice.com
Alex
Postby philm » Mon Sep 05, 2016 8:30 pm
Thank you for your answer
Alex wrote:Could you please provide us with additional information about the issue, please describe what exactly happens.
Behind my reverse-proxy, my portal is functionnal (except doc edition):
- administrator is able to set/change every parameters
- people can register to the portal
- all configured users are able to list their files/documents, shared document etc.
BUT when I click one document, the editor is lauching : messages "Loading document" ... after a while it ends with an error message (pop-up) : "Download Failed, press "Ok" to return to document list"
New (very very curious!): one hour ago, I installed the onlyoffice ios app on my iPad... and it works on the iPad : I can read/modify documents!!!??
It seems that my "nginx reverse-proxy" has a lack of parameters for PC clients, no ?
Note: I tested Linux(Firefox and chrome) and Safari ...same issue with all of them
Thanks
Phil.
philm
Postby Alex » Fri Sep 09, 2016 12:56 pm
Hi Phil,
We need to access the portal in order to analyse the issue.
Please send the credentials to support@onlyoffice.com
regards
Alex
